Bvllsh!t on craigslist.
87ChevyR10
Kansas
NA
NA
NA
Awesome looking car. However, I think the seller has unreachable goals for trades. Those 80's cars didn't exactly have the best engines. Look at the Corvette C3. 200 something HP 350. Sounds like what my truck sports.
Taken straight from wiki:
1987 Trans Am:
The Firebird body remained basically unchanged. All center, high-mounted stop lamps were relocated to a new position between the spoiler and the rear deck lid, and the large Firebird hood emblem disappeared forever. All V8's now received factory roller camshafts, and faced with consumer demands for more power, GM officially released the new 5.7L with tuned port fuel injection. Available only with an automatic transmission, it produced 215 hp and takes the top performance seat from the 5.0L TPI which was rated at 205HP. The 5.0L TPI, however, was available with a 5-speed manual transmission and, in fact, was quicker than the 5.7L TPI coupled with the automatic transmission. L69 production was stopped, leaving the LG4 as the only remaining carbureted V8 used in the F-body. Trans Am GTA (Gran Turismo Americano) was introduced, available with the LB9 305 TPI engine (which was returned to 205 hp) or the L98 350 TPI. Gold 16-inch, flat-mesh, diamond-spoke wheels were standard on GTA, with 16-inch, 20-slot wheels standard on Trans Am.
Firebird Formula was re-introduced, available with a choice of V8's (LG4, LB9 305 TPI, or L98 350 TPI), 16-inch convex wheels, and the earlier Trans Am "Turbo Bulge" hood. The wrap-around wing was updated and now standard on Trans Am and Formula; the regular, flat-surfaced spoiler from earlier Trans Am models was now made standard on Firebird. Trans Am and Formula were also offered with an optional 140 mph speedometer.
WS6 was standard equipment on the Formula and GTA from 1987 to 1992, and optional on the Trans Am. WS6 from 1987 thru 1992 included 36 mm front sway bars, 24 mm rear sway bars, quick ratio steering box, gas filled struts and 16" Wheels with 245/50R16 Tires. Later WS6 cars used ZR rated tires.
The Trans Am GTA was Pontiac's pride and joy with a standard 5.7L 350 Tuned Port Injection (TPI). Many people like to say, incorrectly, that the engine itself was pulled directly out of the C4 Corvette, which itself began using the engine in 1985, but the heads on the Corvette were aluminum whereas the Firebird heads were cast Iron, although it did give the GTA performance numbers comparable to GM's flagship performance platform from whence it came. The GTA came with a standard TH-700R4 (4L60) automatic transmission, A/C, new seats with inflatable lumbar and side bolsters, special door panels, epoxy-filled emblems, body-colored ground effects, a special GTA horn button, and the legendary WS6 performance handling package. All of these options were packaged into the Trans Am under the RPO code Y84, and the model was produced until the end of Third Generation F-body production in 1992.
Dealerships could finally order a Firebird Convertible from a recognized coach builder that was already converting other GM products (though more than a dozen other companies had been converting F-bodies into convertibles since 1982 for Pontiac & Chevrolet dealers). ASC (American Sunroof Company, Later "American Specialty Cars") (of ASC McLaren fame) offered Pontiac Dealerships a Firebird/Formula/Trans Am/GTA convertible. ASC was contracted to convert all of the official Camaro Convertibles from 1987 to 1992. However due to fuel economy restrictions mandated by the EPA, a convertible Firebird would have been assessed a $1200 Gas Guzzler Tax because the LB9 & L98 when paired with a Trans Am or GTA would have been lower than 22.5 average MPG. For this reason Pontiac did not directly offer a convertible through dealers like the Camaro. However these were not an official Pontiac offering, they are considered coach convertibles. The conversion of the Firebird was identical to the "Factory" Camaros of the same model year. The exception was the obvious cosmetic changes, the rear quarter caps, spoiler (Which was a Base spoiler Wing cut off) and the high mount 3rd brake light were Firebird convertible specific.
To order a Firebird Convertible the dealership would order a T-top Firebird and have it Drop shipped to ASC, One Sunroof Center, Southgate, MI 48195 for the conversion alongside "Factory" Camaros. Once complete, ASC would ship the now Firebird convertible to the participating dealership for delivery. This remained the procedure for dealerships through the 1989 model year. According to ASC they did not convert any Firebirds for the 1990 model year. As popularity increased and car became lighter & more aerodynamic for the 1991 model year the process was simplified as Pontiac offered a convertible through normal dealer ordering channels via RPO's. A Total of 173 Firebird Convertibles were reported by ASC for 1987.
donmateo
WI
Agreed, don't think it's worth what he's asking for. Definitely don't see them in shape like that in the rust belt, though. Didn't know the other stuff about it, though. Thanks for sharing!
The88
Mhmm
South Louisiana
ThatGuy
1987 Trans Am:
Actually, the asking price is fair and if the seller sticks to his guns at all, he will probably get something near his asking price I'd be extremely surprised if he can't get at least 10K out of that car. Truly nice 3rd gens are starting to bring in a lot of money.
EDIT, I thought the asking price was 13K, lol. At any rate, the trades he's looking for are in the same general price range. The seller also mentioned throwing in some cash if needed.
Stewzer55
Ohio
Stew
R30
80s Fuel Injection cars really did two things, improved fuel economy and reduced emissions. Only once did they really get the fuel and ignition controls solid did real power start to get made. Look at the Grand National, it had a distributorless ignition system and sequential fuel injection and was the hottest thing around. Compared to the TBI and batch fire TPI setups using modified HEI distributors there's no contest. Lots of the early computers were pretty crude and didn't have very much processing power, starting with the 747s or so in the late 80s. Plus a lot of these engines were still running wimpy cams, awful swirl port heads and gears better paired with a non-overdrive transmission.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
I agree, the GN was way ahead of it's time.
The third gen car's suck it from a performance standpoint though. The fact that there's like five different induction systems and the 305 is a joke anyway, didn't help the aftermarket embrace them at all.
The Mustang, if you got a 5.0, you got the same 5.0, from the lowly LX Coupe, up to the loaded GT convertible. Same powertrain, same processor, same engine wiring. Made it easy to make parts for them.
My first car was an 88 IROC, my second was a 5.0 LX lol.
yevgenievich
Place
Name
Year
Model
Size
Thirdgens excelled at driving. A lot of guys started running fox bodies in f-stock class and then realised that no matter the power they could not keep up with f-body on the auto-x course(305's were the weapon of choice there). Obviously i am biased towards thirdgens, but the fox did have easier power potential. Pontiac should have made more TTA's (turbo trans am).
87ChevyR10
Kansas
NA
NA
NA
Truth be told that the 80's Firebirds/TA's were more aerodynamic than much more expensive sports cars.
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
I've always loved third gens, if I could find it, I'd get my 1983 Crossfire T/A back, it was actually used in Smokey and the Bandit Part 3.
Right now though I am going to mate my favorite third gen engine to my favorite truck. :)
RetroC10Sport
Jay
pontiac aztek
This dude is on drugs.
"AS IS" $2500 OBO
Being sold for parts/salvage.
This truck does not currently run, transmission went out.
My intention was to rebuild it, I always really liked the body style before step-sides got to many of those feminine curves to them.
Looks like I'm never going to get to rework it though, and I'm finally ready to part with it while someone may be able to take over and do something really cool with it. Let me know if interested.
87ChevyR10
Kansas
NA
NA
NA
Yeah, I don't get the prices folks put on these vehicles. I've seen several squarebodies in my area in much worse condition than my truck asking 2500+. I'd be lucky to get a grand for my truck. It's not pretty, but it's mechanically sound, mostly.
zapattack
