Building Gauge Cluster
Splandman
Crescent, OK
Scott
Nice looking but $900? :eek:
Almost all of them are pretty expensive. Dakota Digital is a couple hundred cheaper, but when you have $8k in engine, $2k in trans, more in lift, tires, stereo, blah blah blah, what's another couple hundred to get what I like?
QBuff02
Central IL
Quincy
I like that you have a trans temp gauge. Are you just going to go without a tach? I'd like to have the trans temp but then I would need to run the GM Motorsports Fuel/Tach combo.
Trans temp is just as critical as coolant temp, especially if you're going to do any kind of pulling which is part of the intention of this build.. Lol and the tach I have up on the dash, not sure if it will stay there once I finish out the dash/gauge cluster but it just might have to since there's probably going to be another gauge or two in the mix along with the new mechanical speedo. And I know some don't like the tach on the dash, but that's where I've always put them except for on my old Z28, I had it down on the center console in front of the shifter. It grows on ya.. Lol
Lostranger
Marion, NC
R30
Enjoying this thread. I've thought a good bit about how I want to handle gauges, and these posts are helpful.
dvdswan
Port Orchard, WA
Dave
Ok, its not a C/K dash but I built this for my toy and included idiot lights for turn signals, parking brake, brights, etc. I used proper sending units that were required for the gauge if needed, otherwise I tied into the factory harness using water tight type connectors.
roundhouse
atlanta ga
justin
77,78,79,80 ?
The printed circuit can be eliminated
All the gauges , at least the one I have , have a tiny stud on the back that a barrel connector could be plugged onto
And you can buy tiny LED lights for gauge backlighting and indicators
Edward Koleman
Pittsburgh
Ed
V20
I’m looking into replacing the factory gauges with something like Equus or AutoMeter. My concern is with the wiring. How do I incorporate the turn signals, high beams, etc, with a new gauge installation? If I’m installing individual gauges into the bezel, it seems like I will lose the function of everything else. I’ve been trying to search for answers but not having much luck. Thanks for any help!
You will be reduced to doing what I essentially did. Only I used all my original gauges. I just did this in order to replace the printed circuit board.
View media item 7851
brentjo
