Brakes on differentials?
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
OK so I have been into lifted trucks for awhile but never have I owned one. This question maybe stupid but why do they put disk brakes on the diffs? Like this. (This truck is not mine)
Sent from my XT901 using Tapatalk
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
I have no idea. I see them on trucks with outrageous amounts of lift and big tires. I don't know if its because the stock brakes aren't enough and the need another point or what.
Irishman999
Safford Arizona
Jason
K-1500 High Sierra
They are axles off of a big military truck, like the duece and a half. Thats just how they are designed, the pinion actually points up and the ring lays flat if I remember right.
The reason you seem them on the big huge mud bogger trucks is their strong as is and available off of a surplus of decommissioned military equipment. I have pictures of acres of duece and a half trucks parked butts not nutts in lots outside of Tuscon.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
So is that their front brake or just another point of contact of braking?
oopsman_09
Nampa, ID
Aaron
sierra classic c1500
rockwell axles
That's the brakes. The single brake per axle works because they are tied to the pinion speed, so there's a lot of mechanical advantage.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
OK then. Thanks guys for the insight. I really dont know much about trucks above a 3/4 ton
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Just as your torque is multiplied by the differential so is the braking power. So if you can slow the pinion down you multiply the braking power through the gearing of the axle which in a 2.5 Rockwell out of a deuce and a half is 6.72
Those are most likely 5 Ton Rockwells, off a Deuce. By Deuce I don't mean a pile of ****.
Linville33
Clinton, IA
Justin
K20 Scotsdale
SBC 400
I'm familiar with the nicknames of duece and duece and a half.
BowTieJockey
Tallahassee fl.
Trey
Those discs brakes are also a lot lighter than the stock huge brakes that are offers own on those Rockwell axles
Sent from my HTC6500LVW using Tapatalk
sean1960
Wylie Texas
Sean
Custom GMC
Those axles are referred to as top loader axles. The pinion brakes that you see work very efficiently If you have a locking differentials. If you have open differentials and one of your tires comes off the ground that axle doesn't help you stop. That set up is used off road. Although there have been some similar factory setups used in conjunction with normal brakes. Usually a park brake at the back of the transmission or transfer case.
margramby
