Brake light problem
Scooby3242
Bedford, Texas
I have a 1973 GMC truck and my drivers side brake light will not work. I chased problem all way to the firewall where the tail light harness plugs in before going into the firewall. It appears the passenger side uses the green wire and the drivers side uses a yellow wire that is not getting power. Any ideas? The only other thing i could think of is maybe the brake switch connected to the peddle. i believe it has a orange and white wire but not sure if that effects the difference between the driver and passenger brake light.
gpmorgan
Tupelo Ms.
greg
I think the yellow wire gets its power from the combination switch. I could be wrong. Did you check the ground for that side?
Scooby3242
Bedford, Texas
no I did not check the ground but the tail light works when the headlights are on, is there a separate ground for the tail light and brake light?
gpmorgan
Tupelo Ms.
greg
I think they use the same ground. Do all the other lights work?
Scooby3242
Bedford, Texas
Well the dash lights don’t work and the cab light doesn’t work . Not sure if they are connected somehow
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Do the turn signals work?
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Yes turn signals work and so do the flashers
Do you have continuity in the wire for brake lights from front to back.
Scooby3242
Bedford, Texas
I didn’t check, the only thing I have used is a test light. I have a multi meter but I will need to figure out how to check continuity with the meter.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
That’s what I’d start with you can put the common ( black) lead to the frame and back probe the brake wire at the bulk head connector if you have continuity it’s shorted to ground and could be rubbed threw somewhere
Scooby3242
Bedford, Texas
I did check the plug at the firewall with a test light and there was no power coming out from the cab on he yellow wire that goes to the drivers brake light. The green wire that goes to the passenger brake light has power tho. Not sure if that matters. I tried looking at the wiring diagram and I think the test I did was right but that diagram is hard to read
Scooby3242
Bedford, Texas
I’ll try that
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
It still might be shorted to ground I’d check it like I described.
goodwrenchca
