Brake light problem
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
Orange wire is + 12 volt to brake light switch . White is hot after brake light switch to turn signal switch where the brake lights are canceled for the left side when the left hand turn signal is activated and the same for the right side . so if all the 4 ways and turn signals work but no brake light on one side then the turn signal switch is bad. you can test this by getting a new one and just plug it in and see if the brake lights work before you take the steering column apart/
Scooby3242
Bedford, Texas
Ok I’ll try that thanks
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
Sometimes the turn signal stalk malfunctions (doesn't return to neutral position after making a turn) and will also cause the brake lights to malfunction. They are both part of the same circuit. Bad grounds are a good place to start regardless.
Scooby3242
Bedford, Texas
Ok I will try all the options tomorrow
Scooby3242
Bedford, Texas
I finally got around to looking at my brake light problem, it was a bad turn signal switch, I changed it out and everything works, thanks for the help.
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Cool thanks for the update.:waytogo:
smoothandlow84
Steve
That is the problem with mine...bad turn signal switch. My switch is worn on the inside of the column....Ijust have been too busy to tear down the column. By the looks of business, next year is gonna be busier....uuugh.
Scooby3242
Bedford, Texas
It was really easy after borrowing the steering wheel pulller and locking plate remover from autozone. The easiest way I found was to tape a wire to the end of the plug part and tape the prongs so they don’t get caught pulling it up through the steering wheel the tie the wire on the new one and pull it back through, took about 10 minutes but my column doesn’t have tilt or cruise so not sure if it will be harder
74propu
florida
austin
5.3 / ?/454 tbi
I am happy you have them working again. I have had the same problem a few times .the way you described the systems I had the feeling the switch had gone bat ****.:happy107:
smoothandlow84
Steve
Uuugh. I have tilt AND cruise...sounds like it's not gonna be easy
74propu
florida
austin
5.3 / ?/454 tbi
Same way tape a string to plug pull it out then retape it to the new plug and pull it back in with the column straight
smoothandlow84
Steve
My problem is not with the wire connector, its the actual clicking return to neutral mechanism. The mechanism is so worn that the turn signal will not return to the neutral position after completing any left turn
74propu
florida
austin
5.3 / ?/454 tbi
ok it could be a easy fix 1 the little cancel spring could be broke or missing .2) the cancel cam could be wore the frick out . take it apart both parts can be bought at any auto parts store.
jonahhouse
