Brake light keeps going out
84GMCSierra
Central Arizona
C2500
Good Morning everyone. Got a question about my right brake light, on my 84 C2500. I've replaced the socket/pigtail twice now, and the brake light keeps going out, then will start working again. When it works, it goes for quite awhile then all of a sudden it quits working. Taillight on the right never goes out. Just the brake light. No issues with the left side. Ground issue? I'm thinking of replacing the harness as I know it's kind of a mess from being a farm truck at one time. Who do you all recommend for one that isn't crazy expensive? Or should I just take mine out and make sure it's in good shape?
Thanks and hope you all had a a good weekend.
when you say "out" do you mean it just wont work, it works with tail light at half brightness but it wont work at brake at full brightness, does the turn signal still work?
Or you mean the bulb burns out? If the bulb burns out on brake, but it still works for tail/turn, then you may just have crappy bulbs. The filaments are different, so you shouldnt have them both burn out for an issue only affecting one circuit.
Jgonick
West Texas
Joel
Do easy things first. Check the connections of DK-GRN-19 wire. Make sure it is connected well at turn signal switch connector (steering column) and the bulkhead and there should be one at the back of the truck on the run to the tail lights.
FYI- DK-GRN-19 turns into a YEL at last connection before right tail light
And yes, check the ground. see attachment.
84GMCSierra
Central Arizona
C2500
Thanks everyone. Everything but the brake light on the right side functions normal. Might be cheap element but will check all the wiring
Jgonick
West Texas
Joel
Even the back right turn signal works with the brake light out?
They use the same filament of the bulb and wiring from the turn signal switch.
I thought th turn signal uses the smaller filament
Well, now that I think of it, that makes sense, because the turn signal would need to stand out from the tail lamp right? And when foot on the brake that needs to flash and be obvious
Auburn, Washington
Nvm
Jgonick
West Texas
Joel
If- big “IF”. It truly doesn’t work when brakes are pressed. AND everything else works on back right (right turn signal and hazards). I would suspect a bad turn signal switch.
Turn signal switch provides different power sources to the DK-GRN wire depending on braking, right turn signal, or hazards.
YakkoWarner
Central Texas
Wolf
R2500 Suburban
A bad ground can be confusing - what will sometimes happen (my friend Dave's 1987 Chevy did this one) will be if the ground is bad, current will partically flow back through the other filiment and make it seem like its working - you press the brake and it comes on, turn on the lights and it comes on - press the brake while the lights are on, and it goes off! On tail light and marker lights, I always suspect the ground to be at fault 1st. As old as these trucks are, corrosion and dirt have had plenty of time to get in and work their evil....
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
Eliminate all the other possibilties first, but if you have random taillight issues that can’t be solved, more than likely you have a defective turn signal switch. There are a bunch on contacts that have to make and break connections for the brake and turn signals to function, it’s kinda amazing they don’t fail more often than they do.
84GMCSierra
Central Arizona
C2500
Blinker works fine
I'm already planning on replacing the switch after I get my engine next week. It's probably the original.
jlyon1006
