Block Flush
ballencd
Columbus, NC
Charlie
1988/1991/1983/1984
V10 Suburban/V1500 Suburban/M35 bobbed w/dump/M1010
5.7/5.7/LDT 465-1c/6.2 diesel
I tried Vinegar once. Hoses got very tight (under a lot of pressure) and when I opened the cap (when cool) it blew vinegar all over the engine compartment and even after flushing with a lot of fresh water there are still rust stains everywhere. I wouldn't recommend it at all. Let me know what works as it needed a radiator and still does and I want to do a good flush before I replace it.
WFO
Texas Panhandle
Thank you for your reply. I was wondering what effect vinegar would have.
I'll be firing it up within the next week. Going to leave the old radiator in for a few days, and try the Prestone Flush+Cleaner. Then put the new radiator in.
Wumbo
Illinois
Rob
That's what I did last month. Worked fine.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
I've used the Prestone too and it worked well for rust. It did take a ton of flushing to finally get all the crud out of it though.
85 CUCV
Homer Alaska
Terry
CUCV M1009
6.2 l diesel
FYI Vinegar will not hurt any of the metals in your system and is very effective in removing the lime scale in the system.
Just flush thouroughly before refilling the system with coolant
  • Like
Reactions: WFO
WFO
Texas Panhandle
Much obliged.
That's why I was thinkin of using vinegar, because it removes lime buildup.
DannyG86
