Black exhaust smoke upon startup???
Chaz
USA
Chaz
V1500 Suburban
350 tbi/th400/np241c
Just noticed recently black smoke out of the tailpipe upon startup on my 89 350tbi,,,,,,its not constant,,,,it goes away real quick after startup but its starting to occur more and more frequently,,,,,bad valve seals or is it prob fuel system related???
smurph20
Clyde, Arkansas 72717
Brad
350/SM465/NP208/4.10's
Black smoke is burning rich. If it were blue then id say oil.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Check for drops from the injectors. gander at them while someone cycles the key on and off, waiting 12 seconds between each cycle. do not go to the start position. If you see fuel, you need a throttle body rebuild kit. round $45 for a good one.
Chaz
USA
Chaz
V1500 Suburban
Its got a holley 670 tbi unit on there,,,,bout a year old,,,,,you guys helped me fix engine probs on it before,,,,it was idling poor and found out it was the msd coil when I replaced it with stock one,,,,,no problems since until the black smoke im gettin now,,,but ill check the injectors and see anything looks different than before thanks Jim,,,,
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
Probably the throttle body. Those things are known to cause problems right out of the box.
thom9719
