Big Block Radiator Hold-Downs
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
What radiator hold downs is everyone using when they swap a big block radiator into their C10?
After adding AC to my truck my stock radiator wasn't doing the job. I added the Big Block radiator from an 85 C10 and installed a set of electric fans from a Windstar. I fabbed up a set of mounts for the fans but I'd like to use the factory hold-downs for the radiator.
GM doesn't make them any more.
Every scrap yard near me doesn't have them.
I can't find an aftermarket source for them, but there must be one. I see a bunch of folks running them, and I'm pretty sure the trucks weren't all born with them.
Can someone please point me in the right direction?
Thx,
Joo
yevgenievich
Place
Name
Year
Model
Size
I extended a set of factory mounts when doing install on my old suburban
nvrenuf
Mobile, Al.
As far as I know, now one makes reproduction brackets. Used is likely your best option.
disenough
Rock Hill SC
brice
I welded 2 sets of small block hold downs together and a 1/4 inch spacer underneath them.
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
That's crummy. Thanks though.
Perfect! That's totally do-able. I know where to find a set of those, I think.
Joe
disenough
Rock Hill SC
brice
I did use new rubber pads for a big block radiator.
I know you didn't use your shroud but just to help
others I used the small block shroud with a little trimming .
JoeR Jr
Stokesdale, NC
Joe
6.0/4L80E
Today I ordered a set of 350 hold downs from LMC. I'll stretch them to fit when they arrive. I also ordered the correct rubbers for the big block radiator.
Joe
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Brothers truck has the one piece hold down I believe, I would prefer that anyways.
yevgenievich
Place
Name
Year
Model
Size
These were extended with some flat stock that I had
My big block trucks have all had one big upper panel that retains the radiator, rather than the two little individual mounts used on the small block trucks with smaller radiator. And I believe the two individual mounts were only used in the '81-up trucks.
#32-0984 is what my 80 K25 350/400/205 with A/C came with from the factory. It is the large 4-core radiator and has the solid bracket across the top as shown in that LMC diagram.
Catbox
Peter
C20 Silverado Camper Special
My big block has the large retainer across the top of the radiator.
As seen below...
nvrenuf
Mobile, Al.
It’s a year model thing, as stated ‘81+.
I’ve got a CUCV radiator set up on my ‘91 Blazer, 2 small brackets with a plastic cover that goes between them.
Paladin
"Teufelshunde"
Wichita Falls, Texas
C30 Silverado Crew Cab Dually
One big plate as Bucket said. :cheers:
mswed
