Best R12 Compressor?
74propu
florida
austin
c10s/b c10 s/b c10l/b
5.3 / ?/454 tbi
The engine is a 96 it is as I pulled it out of the 2500 it was in . the truck is a 80 it was a diesel p/u originally and those are the a/c lines that was in it
74propu
florida
austin
5.3 / ?/454 tbi
Wish i knew that before i chose the 92 accessory system
Sent from my SM-G950U using Tapatalk
You can get a new A-6 set up 4 R-134 I did in my 86 big block
usar17
PA
K20 Silverado
TBI350/700r4/NP208
But id need to rig it for my 1992 bracket thats R4
74propu
florida
austin
5.3 / ?/454 tbi
Your compressor like this one
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Hahahaha nice use of string.
No mines a passenger side 6 rib serpentine belt mount
74propu
florida
austin
5.3 / ?/454 tbi
Ok I was trying to see if that is the compressor body you have ??? that is a setup I did on my 86 it has small block suburban a/c lines and home made mounts . but that compressor is a r-12 unit and when I got it done I went to o'rileys and got a brand new r-134 compressor for It . so you can get a new R-134 compressor fore your setup
74propu
florida
austin
5.3 / ?/454 tbi
the string is so I could get a belt that would fit
yevgenievich
Place
Name
Year
Model
Size
You can use r4 compressor with r134, they are just hit and miss. The only other most direct swap in using tbi brackets is the sanden with brackets that I could find
usar17
PA
K20 Silverado
TBI350/700r4/NP208
Ya it looks like im gonna do a sanded swap. Thanks everyone :)
ben_swager
