Bed swap issues?
cmcgoo
el paso
chris
k30
Got a k30 with a 9ft service bed that I want to remove. My question is.. would a normal 8ft bed fit easily in its place? Or will modifications be needed?
Rickf
Grafton NH
1974, 1954 & a 1937
If you center the rear axle in the wheel well opening, there will be a larger than "normal" gap between the bed and cab.
Turbo4whl
Downingtown, PA
Wayne
Jimmy
Assuming your K30 is duel rear wheels, also an issue with inner tire clearance. The factory 8' bed would have the widest rear axle. Then extended fiberglass fenders to cover the outside tires.
Most service body duel wheel trucks have a narrower rear axle. This keeps the rear wheels more inline with the front. The bed is over top of the inner tires. You could extend your inner fenders but you loose the full 4' between the fenders on the bed floor.
SquareRoot
Dual. And what is a "service bed"? Curious minds want to know. Better yet, spit a pic.
But in reality, there could be dueling axels
Auburn, Washington
OP depends whether your truck was originally a pickup or a cab n chassis. Take some measurements. You can look up all the dimensions on GM heritage center. But if you can measure a long bed pickup you can compare.
Spanky74
