Bed rails with a tool box?
SirRobyn0
Rob
nope, its in my lean-to Good memory lol
I found the running board Of mine that had a bracket, I foudn the pic looking for the tuffbox(?) pic. Its not super tall but its not short either.
The lid looks just like mine!
I need a D/S bracket and Ted is going to send me one of his spares, which is on not rush as the slightly cracked up one is doing just fine. Honestly I expect it's got a few year left in it, I just don't wanna wait to do anything until I fold the board over on day and land on the ground.
The toolbox opens up, its not super deep but it may be the same as yours deep wise. there is no feet under it, or on the rail area. and it just has a few holes where someone had mounted it before.
The 2 sides have a center push button that lock(No key tho) and there is nothing else to the inside but inside lol
SirRobyn0
Rob
I think yours might be missing the legs, everything else sounds the same. Mine is not all that deep either which is fine that mean I can reach stuff. Mine has legs and holes in the sides as well. I bet if you look at the bottom there will be cut outs for bolts that the legs would have attached too. Both sides on mine lock, and I do have the key, but let me tell you it took some work to get those functioning properly after it sat outside in the dirt for over 10 years.
is it because it couldnt support the weight of a lot in the center?? Igot the idea i wouldnt be getting much other than long tools or similar into it but I could see the weight being why
I think so. Mine is not particularly heavy gauge plastic.
If I ended up using it I probably would not have much other than hand tools and a maybe a small bucket or basket at the ends with a couple things. I like the big open lid kind of tool box lol
I got a pick of my gmt 400(dad uses) thought you may like to see LOL
SirRobyn0
Rob
Ya, I'm sure it would be fine like that. What I did when I broke my one leg was just to make a 2X4 box with the height I wanted and bolted it to the bottom of the box. I never took a picture of it but I can if you wanna see it.
75 k25 , not very useful right now since the U joints and front shaft stuff for the np203 system are worn and etc.
Then the Th350 spit a chunk of metal on the ground thats quite big, and its noticeable hole in the case lol..
Then the engine just would need TLC I hope but idiots were the last ones to play with the qjet leaning and riching things out and also having the plug wire order about as wrong as possible. yikes stuff.
Has a dump bed on it!
Cantrell299
