Barn Door Alignment?
Girth
Olympia WA
Garth
V2500 Suburban
Couldn't find anything using my Google Fu. Anyone have any tips for adjusting how the barn doors on a Suburban hang?
Got a pair of used replacements to replace our rusty doors. Kinda wishing I'd never unbolted the old rusty ones now. lol Fiddling with the hinge adjustment to try and get them to hang right is infuriating. I ended up with three pairs of hinges between the two sets of doors, and looking at them, it seems some have a slight bend (some are flat, some bent to varying degrees) in the plate that bolts to the body. Maybe I should get them close, then remove a hinge and throw it in the press to bend it a tad? That seems ridiculous, but I don't see an easier way to do it.
As an example.... LH door, wide gap to the body at the bottom, but TIGHT up top.
Auburn, Washington
I’ve never messed with barn doors on any gen burb, but have always heard how people don’t like them (not sure why, maybe this is why?).
It’s very reasonable they could be tweaked or bent, or need to be bent to align. Assuming you can use body shims maybe to open the tight gap.
Did you use the hinges off the original doors if those had good gaps and closed ok?
I’m mostly spitballing.
Is the gap even across the top? Hopefully not.
Girth
Olympia WA
Garth
V2500 Suburban
On the LH door, sorta. Pretty close. If I could get the top of that door to come towards the center even 1/16th, it'd be golden. RH door, it's so far out, I gotta start from scratch. Sitting WAY low. Seems like tiny adjustments, where you can't tell if it even moved while you're holding the door (watching my wife struggle with the ratchet lol), make BIG changes.
There's really not a great way to shim them, as the hinges fit through slots in the body and there just isn't much room to move them like that. Getting shims in there would be a nightmare too.
Bending them, well it's at least 1/4in thick steel strap. Doable.... but dang.
I ended up with 3 pairs of hinges. The "new" doors still had them on one door. We were playing musical hinges for a bit, trying different combos to get the doors to fit better. That's actually where the "bend them" idea came from, as I noticed some had a slight bend to the flat that bolts to the body, and others did not.
Probably a bad sign that I couldn't find anything discussing this on a forum search. Ugh. There's a service manual around here somewhere, if I can find it. Maybe it'll have some insight.
Cousin_Eddie
