gearheadmike
- Mar 6, 2014
- West Chazy Ny
- Mike
- Sierra K2500
1986 GMC Sierra k2500
Ok so I found that my pass side Lower ball joint is bad and needs replacing. I know in order to remove it I must remove the following?
Wheel
Caliper/brake pads
Locking hub
Lock nuts
Spindle
6 housing nuts then housing
Axle shaft
Now this is my first time ever replacing ball joints do I have to remove the knuckle compleatly or no? Also what ball joint should be removed first bottom or top?
I will be buying the replacment parts from rock auto (Moog parts)
When reinstalling can I press in both top/bottom ball joints at once or seperate?
Wheel
Caliper/brake pads
Locking hub
Lock nuts
Spindle
Axle shaft
