Bad ground or wiring
Snoots
Roger
Jimmy Sierra
350 w/203
Suggestion:
Disconnect the battery at the ground terminal.
Go through the truck EVERYWHERE and at each and every ground connection, one-by-one remove, clean, apply copper anti-seize grease, and reinstall.
Clean not just the connector but the part of the truck where it attaches. If the screw/nut that is holding it is rusty; replace it.
Make certain that you have a ground wire from the frame to the body AND to the engine.
You're going to have to get under the hood, under the front and back bumpers and under the dash just above the parking brake.
sdmartin1990
US
Suggestion:
Thank you for all the information and support. I am planning to start early Saturday morning. I have the sandpaper ready. Just need the anit-seize. I definitely want it right and not have to worry about it anymore.
Sent from my SM-G892A using Tapatalk
zapattack
