Bad ground or wiring
sdmartin1990
US
Thank you Qbuff02, great info. Since you brought up the bulkhead connector. I wont say what happened. Its embarrassing, that might be my issue.
Sent from my SM-G892A using Tapatalk
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
Sounds like some sort of short to ground, accidental reversed polarity or similar circumstance.
Telling what happened at the bulkhead may be insightful for a solution to your issue. Don’t withhold evidence, lol
sdmartin1990
US
Gauges, radio, dome light.
sdmartin1990
US
Thank you Preston
sdmartin1990
US
Thank you Frankenchevy, I am hoping that's it. But I had an accident with at the bulkhead. So that might be it. I will check everything this weekend.
sdmartin1990
US
Frankenchevy, I apologize for not answering the last part. Didnt see it, anyway I just finished doing oil change and replacing oil pan gasket. I was filling with oil and using a tall funnel. I didnt notice the funnel filled with oil and funnel slipped from my hand. And you guessed it, it spilled all over brake booster and firewall.
Now I said it, it is funny. Crap like that always happens to me.
Frankenchevy
Proverbs 16:18
Square
CUCV
Small
and this is when all your issues started?
sdmartin1990
US
I believe so. I bought the truck knowing I had issues with headlights and radio would intermittently work. I figured easy fix. I replaced battery and headlights did better and radio worked. I was thinking I found a bad ground.
I didnt think of looking at brakes lights until I installed new lenses. And I spilled the oil before I did lenses. So back to..... I believe so.
Preston
Mechanicsville VA
Preston
Could be all on one circuit, and grounded independently have you checked your headlight switch?
sdmartin1990
US
I have not. But planning on taking my time trying to find it this weekend.
sdmartin1990
US
My situation
Snoots
Roger
Jimmy Sierra
350 w/203
Toward the upper left, what is that 'crusty' looking wire? Is that burnt?
sdmartin1990
US
Thank you for replying. Hey sorry for late reply. I am new to app and figuring it out. The upper left (if I see the same as you) it is single wires on the left side. The right side are multiple wires and it looks like black mastic covering. Hope that makes sense
sdmartin1990
US
Also, to answer your question. Good looking out. I didnt notice that until the second time. I will have to look and clean the wires.
zapattack
