Backspace 15" vs 17"
89GMCJimmy
ivan
1989 GMC Jimmy 15"x8" with 3.75" backspace and 1/4-3/8 space between rim and Tie rods
If I move up to a 17" rim will a 4.5" back space work?
Not too many options for 17" or 18" (simple style) rims with less than 4" back space
If this has been answered already sorry I haven't found yet
Thanks
89GMCJimmy
ivan
i'm hoping to reduce some steering play/slop. With the push pull steering it will never feel super tight but it will feel a litter tighter
i wanna reduce sidewall height keep 33" over all
RoryH19
Rory
R10 Silverado SWB
I'm going with 17s with 33s as well.
Same reason as you and would like to put a newer rear axle with disk brakes.
Ebay has several options that are supposed to fit our 6 lugs.
There are American Racing 17x9 that are very close to the ones you have.
89GMCJimmy
ivan
Rory
Do you know what is the MAXIMUM backspacing that will fit?
My 15" with BS 3.75" is pretty much it, I think slightly more with a 17" rim but not sure how much
If a 17" with 4.5" backspace works that would open up many options
colonel mustard
louisville ky
steven
k5 blazer
I had a 15x10 with a 3.5" backspacing. I just moved to a 17"x9 with a 4.5" bs. it clear everything with room left over.
TubeTruck
East TN
Denis
Suburban K10
LQ9
What size tire are you running? How flush is it to the outside of the fenders?
colonel mustard
louisville ky
steven
k5 blazer
The rear is mostly flush. The front sticks out about 1/2” maybe a little more. It looks great. I just prefer thee wider stance.
I’ll take some pictures today
Odis
