Axle ratio help
84GMCSierra
Central Arizona
C2500
Hello everybody. I'm trying to figure out what the gear ratio is on my 84 base model 3/4 ton Sierra is. The SPID says GQ1 Rear Axle - Standard. I tried finding it online and the GQ1 isn't listed. Can someone help me out with this please? Engine is a 350, and the trans is a TH400. I'm hoping they are something for daily driving, and highway use once in awhile.
Thanks
legopnuematic
Licensed Junk Dealer
MO
Spencer
Or pop the rear cover and count the teeth/find the numbers on the ring gear to verify. If you haven't changed the gear oil in your ownership it's probably time to do so anyways. Gear oil is cheap compared to rebuilding a rear axle.
Keith Seymore
Motor City
Keith Seymore
4.3L
Well done, Lego.
Just to flesh it out a bit more: I see C20903 W LT9 with the three speed auto (non overdrive = MX1) so I'd call it 4.10:1.
K
Keith Seymore
Motor City
Keith Seymore
4.3L
Thanks
Correct. For base axle GQ1 the SPID shows GQ1 but doesn't specify the numerical ratio, because it varies (as shown on the Powertrain Chart).
For an optional ratio: The SPID will show the RPO and call it out by name (ie, GU6 = 3.42, GT4 = 3.73, GT5 = 4.10 or whatever).
K
84GMCSierra
Central Arizona
C2500
K
So I need to pull the cover and count teeth to find out what it is?
mtbadbob
Montana
Bob
V20
Put it on a lift, turn your rear wheel one revolution, and count how many times the drive shaft rotates in that same revolution.
This won't work if it's open diff,you can push the car on the ground,1 revolution stop every 1/4 turn check and mark your drive shaft. Or jack up 1 wheel and turn it through 2 revolutions and count your driveshaft turns. Nevermind it's 4.10,look at the power train chart @legopnuematic put up for you. All 350s with the mx1 transmission and gq1 axle are 4.10
mtbadbob
Montana
Bob
V20
This won't work, if it's open diff,you can push the car on the ground,1 revolution stop every 1/4 turn check and mark your drive shaft. Or jack up 1 wheel and turn it through 2 revolutions and count your driveshaft turns. Nevermind it's 4.10,look at the power train chart @legopnuematic put up for you. All 350s with the mx1 transmission and gq1 axle are 4.10
Why won't it? It's worked for me before on my Olds...
It will work on a posi but not an open differential because of how the diff it's self works on a posi both wheel spin same speed on a open diff they don't.
59840Surfer
Montana
Joe
Partly true ----- on an open differential, the side and spider gears change the revolutions in relation to the driveshaft - so the numbers won't be anywhere near accurate.
You can get in trouble with the Gov-Loc® system too because you CAN turn one axle slowly and the posi-effect won't hook up ... and again you're counting side gears and spiders.
The tooth count is always on the ring gear --- simply like this as an example ---> 38:12 or 33:07 --- something like that --- in form, but not necessarily those numbers.
Happy hunting!
cornholeeo
usa
corn
so youre trying to tell me that if you have rr wheels off the ground and the trans in neutral, spinning the drive shaft by hand that you cant get a close to accurate ratio. There is no slip from drive shaft output to the wheels.Any slippage is from side to side
The spider gears and axle end gears come into play. You could rotate the driveshaft and watch the tires if they both spin the same direction equally you can count number of drive shaft turns to 1 turn of the wheel. If 1 wheel spins clockwise and the other spins counter clockwise,you will have to hold 1 tire stationary and turn the driveshaft,count how many turns to make 2 turns of the tire.If you want to just turn the driveshaft and count turns without one wheel stationary or both wheels spinning the same direction,you are more than welcome to try.
  • Like
Reactions: WFO
WFO
Texas Panhandle
I never even thought to rotate the driveshaft 2 times on an open differential.
But, rotating it once and doubling the number of wheel rotations got the same result.
jimlayhee
