ATF capacity
BJedi76
Soldotna, Alaska
B.J.
GMC Sierra Classic 1500 4x4 SWB
305”
1986 GMC K1500 NP 208
There’s seems to be some great debate over the fluid level.
I have read:
- 2.5 quarts/5 pints
- 10 pints/5 quarts
- fill till spill
My Chilton manual says 10 pints.
My Haynes manual says Fill until pours out.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Fill the sump, run in neutral and fill to it levels out, all depends on whether you filled the torque converter before installation
gmbellew
Kansas city
glen
suburban 1500
the np241c transfer case is fill to spill. I'd guess it is probably the same for the np208 transfer case.
sparky77
