1low4x4
- Feb 14, 2011
- Texas
- Nick
- K10
Hey....lost my cool yesterday. 85 c10 the blue one.
When I put the engine in the truck I used the old pump and reservoir that was already in the the truck back on. It was leaking s one day I figured I'd fix it.
Replaced the pump and reservoir with ones from oreillys, reman.
Fixed the leak but now the box on frame leaks. Developed a bad noise like nails chalkboard. When you turn whee all the way one way and now it does it randomly while cycling the wheel. When it makes the noise the pulley is freezing up and so I pulled the pump off again last night. The magnet inside the reservoir was full of junk. Bad.
Warranteed it out for yet another reman. Installed my pulley carefully and the lines, filled it up and it makes the EXACT same noises and pulley still slips.at a loss.
Did I get another bad pump???? Is something else causing this? The belt isn't new but not bad...the pulley seems to be straight, I did notice that when I turned wheel all the way to side the pressure line tenses up real tight....
I'm to the point of getting my.money back for.this cocksucking reman ********, buying a new pump and replacing pulley belt lines and steering box
