Are these dual shocks factory. Pic inside. 1987 K10 long bed truck
Nasty-LSX
TogetherforeverCovid19
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
So I dont think so but what do I know!! 1987 K10 long bed truck
Redfish
Prairieville, LA
Andrew
V1500
My '87 V1500 doesn't have dual shocks. I don't recall any of those trucks coming with a dual setup from the factory but that doesn't mean they didn't.
Why do you only have one leaf spring? Those trucks came with two leaf springs on the front.
You know that in '87 they were no longer K10? 2wheel drives were Rs and 4wheel drives were Vs.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
My 78 has dual shocks but there an add on. I was going to take half off because I think it might ride better? If there riveted on I'd say original for sure.
squaredeal91
Greg bush
1991 SB
I can barely see the 2nd one hiding under.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Yup 87 mixed up new letters. Thanks for the info. Looks like 2 springs to me. Im going to
go see it tomorrow. The shock mounts look riveted in:oops: like its factory. But ill see it tomorrow.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
That why I was wondering. I dont want to buy something thats not a normal K10 V10 1500 kinda thing. Im not familiar with all this 4x4 stuff. The guy wants $1800 for this so thats not chump change to lose if it dont fit LOL
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Ok so they are factory. Was there a reason. Heavy Duty frame? or suspension? Im just trying to
understand here.
Nasty-LSX
HOUSTON TX
Mi Hung Lo
c10/k10/k20
LSX
Here is another question. What frames were interchangeable with my 85? is it 81/87? Thanks again
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
understand here.
What's to understand? It was more common back then, but quad shocks were popular among the off-road crowd for more control.
You don't have to keep it that way. You can revert to singles if the quads are too cool or too much damping for your purposes.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Factory. I'm guessing the leafs are like that because it rode rough with the quad shocks lol
vr1967
Mississippi
Virgil
k1500
6.2L turbo
If I remember right, GM cut the shock valving in half on the quad shock pair, so it would take longer to heat up the oil in them while off roading.
My 84 came factory that way, but its hard to find aftermarket shocks that have the reduced valving (may not be the proper word) and putting 2 aftermarket shocks on each side usually makes for a harsh ride.
Edit, changed wording above to avoid confusion.
Edit, from the 81 sales brochure:
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
If I remember right, GM cut the shock valving in half on the dual shock shocks, so it would take longer to heat up the oil in them while off roading.
Right. The factory quads used completely different shocks than the duals. Most aftermarket ones use the same shock as the singles and just add another one.
Burban90
