Anyone know trick to install a new (used) door spring?
Jwernatl
Senoia, GA
5.7ltr
Hey all i got a new (used) door spring for '87 v10.
My drivers side is broken.
Ive tried to install this joke of a piece, maybe, 6x. It makes me feel very silly.
Anyone got a trick?
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
Anyone got a trick?
What's the problem you're having? What kind of trick do you need?
I could say "Simply put it in" just as easily as you can say "it's giving me a hard time putting it in". Could you please elaborate as to what problem you're having? IME it seems straightforward, biut if you explain the part you're getting hung up on I'm sure plenty of people could explain how to overcome the issue you're having...
hoagster
California
K10, 1500
5.3l
There is a tool for this also! there is a tool for just about everything! Working on automated equipment I had several spring installation/removal tools and once you figured out the tool it was piece of cake
RecklessWOT
New Hampshire
Kevin
That's even easier! Usually I just guide it into place with a couple big flathead screwdrivers then bang on it once it's wedged into place till it pops over and gets stuck where it belongs. I'll have to remember that, looks super easy. You could probably do the same thing with mechanic wire and keep twisting if you didn't have big zip ties handy. Then just snip off when you're done all the same
sirweesarunch
Oceanside
Take it off and put it in a vise. Wind the spring with a crescent wrench then tap it down to lock it in place. Reinstall. Ps. Trace around the bolts before removing so they go back in their original adjusted location. Done deal.
Rickf
Grafton NH
1974, 1954 & a 1937
I found several videos on YouTube about "S" style GM door spring installation.
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Guys, im actually talking about the 's' hook spring its in the door - its the only type I have in my '87.
Any help is appreciated.
On LMC link below - its #11
.https://www.lmctruck.com/1973-87-chevy-gmc/door-parts/cc-1973-87-front-door-components-2
You absolutely can install this type without removing the door! It's been a while... I'll do my best. get the spring started at the top. With a bar move the bottom into position and tap it down into place. It seems like a mission impossible, but after you 'get it' it's really easy. Maybe you have to tap it 'up' into position, sorry it's been years. But if you understand what I'm getting at, and believe me it is totally possible, you should be able to figure it out.
Jwernatl
Senoia, GA
5.7ltr
Thank you - I just found one on a corvette site - I need the bend screwdriver! I' looked all over the place - kept finding the one with coil spring. Looks very similar to the corvette. - I'l make a tool today.
Jwernatl
Senoia, GA
5.7ltr
that is the KEY -"tap it 'up' into position" it make sense -100%-
I have small pry bar that will work. It will Im confident.
I think I need to...
1. seat the top -
2. put center into the groove and
3. bend bottom of the 's' over with tool (bent screw driver) then..
4. tap up to seat the bottom in to cut goove. (sorta a goove/hole thing)
- I'll take video - and upload if any would like to see.
350 w/203
You need one of these . . .
Jwernatl
Senoia, GA
5.7ltr
Yes, yes I do!
RecklessWOT
New Hampshire
Kevin
jlyon1006
