The 2.5-inch kits at Summit -
http://www.summitracing.com/parts/flo-15936
The 3-inch kit -
http://www.summitracing.com/parts/flo-15937
I used this S-bend kit to work around the 30-gal rear tank (I believe I needed to use the 8-inch offsets) -
http://www.summitracing.com/parts/flo-15927
Added Jeg's universal 3-inch X-pipe kit -
http://www.jegs.com/i/JEGS+Performance+Products/555/30662/10002/-1
A word of caution - if you get the kit for a LWB, you'll likely need two 20-something inches of straight tubing to connect the front S-bends to the mufflers to finish. When I found this out I decided to go the X-pipe route instead of the H (which was supplied) so I didn't need the additional tubing because of how long the assembly is in comparison...but I was still irritated that there wasn't some sort of disclaimer or note because it stopped me cold in my tracks.
A shot under the belly of the X-pipe.
Around the tank.
I was working in tight quarters on the drivers side. The 3-inch tube had to go between the shock and the tank and sneak past the ORD shackle flip kit and run between it and the tank. You can just see the tube behind the shackle in the pic below. This is the part that was making me wish I had gone with the 2.5-inch kit instead of the 3.
If I didn't know better I'd say the kit was made for my truck. The Jegs X-pipe kit is crap (all of the single mandrel bends in the legs were over bent) so I had to build a fixture to square the assembly but, other than that, it was fairly easy. Had I not done the rear tank relo the rear would have worked fine out of the box. Without the additional S-bends, there was no way to slice and dice the pieces I had to make it work (which isn't exactly true however I would have had a mess of weld seems). On past projects I've had mandrel exhausts fabricated and none turned out this snug to the undercarriage and they cost way, way, way more. The hardest part was working out the hangers - mostly because I'm extremely particular and only like the later model ones that look factory.
