Any squarebody van guys? Got a odd question.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
I actually thought about suggestion that, but assumed it wouldn't be enough. It would be cool if you could figure out some way of still having some sort of a pad, but I'd be all about a few moments of angle grinder action in the car vs remove and rearrange.
On your gas pedal what about going to one of those bolt to the floor style? You'd have to see if this would work safely, but the idea would be that you'd bolt the pedal to the floor and let the top part sit over your current pedal or remove it so it can sit on the rod. It would give you more pedal farther back and possibly raise the height a little.
Hmmm, that's a really good idea, hadn't thought of that. That could help. I could probably make something thy would work pretty darn well. Thanks for that thought
And yeah, I'd opt to do it in car instead of removal everytime. I think it would be enough, barely. I also thought about removing a bit of rubber and fabric and padding off of the doghouse area to I crease the room for my foot. Not enough to make it hot while I drive, but theres a big flap of floor rubber that could go.
SirRobyn0
To preface this I've never owned a G-van. I had an old 70's class C RV, on Dodge chassis and now we have 99 class C on a chevy chassis. The old Dodge the dome got quite a bit warm. Not on short drives but on longer ones. It could be really miserable for the driver (me) going distances in hot weather. The newer chevy is no problem. My only point is that if you do something to the dome, which moves it closer the exhaust it maybe fine locally but you'd just intensify heat soak on a long trip. I think dome to foot interference is something you'll get use to if you re-arrange the pedals in a better way.
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Weld the piece you cut off to the other side. Basically shift the factory pad over. Maybe?
I do agree that some kind of pad is necessary. Wet, bare metal is as slippery as ice.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Oh I still have the original runner pad. I'll just trim to fit, and reinstall when I'm done.
Oh yeah, metal pedals when its wet are dangerous. I've done that a few times.
Well now that the pedal thing is figured out for the most part... any of you big footed folks ever try to drive an early 00's Nissan Xterra? It's the worst pedal situation I've ever encountered.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Nope, never have.
SirRobyn0
I never owned one, nor did I have friends that did, but I remember them from when they'd come into the shop. Yea I agree they were terrible. And not just the pedals.
WFO
Texas Panhandle
I had one of those, "why didn't I think of that" moments today. What if I just shave off the outside edge of the pedal? Just clearance it enough to fit my foot.
I also thought, I could drill a hole in the bottom of the gas pedal, and bolt a little block to it so I won't have to reach in so deep to press it?
The simplest solution is often the best, right?
Couldn't you just pull the pedal off and heat up the bend in the picture, and the bend above the picture, so those bends could be bent a little more, causing the petal to be shifted to the left?
Gene King
Connecticut
Matthew
I've got an '83 G20 in the yard. I forget what they call it but it's got upgrades done to it by an aftermarket company sort of like Shelby. Was a sweet rig, shag carpet, suede swivel seats and a sleeping bed. Then a drunk killed himself rear ending it
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
That's pretty cool, sucks about the guy though.
Mines the same way, it's a Good Times Van, was customized my Good Times Inc, custom outfitters.
Carpet threw out, 4 red velvet swiveling captain's chairs, and a folding couch/bed on the back.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Gene King
Connecticut
Matthew
cool photos. I wanna say mine's a Starcraft or Starline or something..could be wrong though. It's a lot like that except it doesn't have the bulkhead behind the bed and it had a removable table between the 2nd row seats.
& yeah it's kind of a long story but he hit driver's side rear corner then went off the road and into a tree. The insurance company totaled it for a bent frame and I bought it back for almost nothing because it was already 25 years old then. I was going to keep driving it but I let the registration lapse while procrastinating hammering the rear corner back into a reasonable shape and they wouldn't let me put plates back on it. They did the guy's BAC and he wasn't just buzzed, he was sloshed and had a suspended license for drunk driving already.
Added a photo of it, not much to look at anymore though. Inside is full of crap
kobedemello
