Splandman
- Jan 1, 2014
- Crescent, OK
- Scott
- K10
I am trying to get a truck ready for my daughter who turns 16 in July. I offered to buy her several different vehicles (a lot of the $$ is hers that she earned) but she insists she wants my daily driver truck. There are several things wrong with it that didn't bother me so much with me driving it but I want it correct for her.
Since I bought the truck it's only had about 1 of the gauge lights working. Also, someone had installed some pod gauges and mounted them under the dash. I didn't like them and wanted the originals used.
Once I took out the gauge cluster to install the bulbs, I noticed it had 3 of the ears that are mounts broken. I also noticed that green box for the cruise was missing. I bought a cluster off of Ebay and am now trying to install it. Here are the problems so far:
I plugged the gauge cluster in and the temp gauge goes all the way to the right (260 degrees) and stays there.
I don't know where to find the wire that would lead to the oil pressure gauge. I was hoping they just took it off and hooked up the one going to the aftermarket gauge but I am not seeing it.
I have no idea where the green cruise box things plugs in.
It does not appear that the wires to my plug were cut anywhere so I am assuming they ran new wires to run the gauge cluster. I found what I think should be the water temp wire with a black fitting on the end laying on my intake manifold. I put it on but got nothing. I think the black end that slides on the prong coming off the thermostat housing is bad but not sure.
Here are some pics but they suck. Was holding my phone wrong I guess.
The second pic is the one showing the wires the previous owner used to run the aftermarket gauges.
