82_k10
- Nov 14, 2021
- Louisiana
- Amadia
- k10
- 350 sbc
Truck is an 1982 non a/c truck with a 350. Had problems with alternator belt squeaking after replacing heads. Changed the bracket for the alternator still squeaked. Changed the alternator and it finally quit squeaking but once I took it for a little test drive the belt popped off completely. Tried adding washers and spacers to areas of the bracket to get it to line up better on the water pump pulley but it’s pretty close. Even had a straight edge on the pulleys and they touch both sides of both pulleys. I’ve tried having the belt looser, tighter nothing seemed to work. One day belt popped off and I looked under the hood and the power steering pump belt was crooked. It’s hard to explain but it was still in all grooves of the pulleys and working just fine but it was crooked. I took the belt off put it on correctly and put the alternator belt back on. And they both popped off. Put both back on and they popped off again. Unbelievable. Tired of messing with it, need help. Sounds like something I’m doing wrong but I feel like putting a belt on is pretty simple. Thanks
