- Apr 11, 2017
- kansas
- Rick
- c20
@AuroraGirl I made this just for you,well, just for me but I was thinking of you. I lost my favorite air bubble(freon tank) had it 30 years. Needed something now, I told you you could do this months ago so I'm showing you how. 1 old school BBQ tank,the kind they won't refill,1 BBQ regulator, 1 air hose coupler,and 2 air fittings. You take the brass fitting out of the regulator,look at it,the hole in the center is the size of a pin,drill the hole bigger,screw it to the BBQ tank,screw the coupler on. To fill it take the 2 air fittings,as in the picture,hook one end to the coupler,1 end to your air compressor hose,open the valve it will fill. Close the valve, disconnect the air hoses and you're done. With the valve closed it won't bleed off over time like the parts store air tanks. Pic 1 old propane tank coupled to my compressor hose. Pic 2 the regulator I took the fitting from,the 2 air fittings I couple the tank with to fill,and a coupler screwed to the regulator fitting. Pic 3 the air fittings,in the coupler,ready for filling the tank.
