Air in fuel lines after sitting over night on 6.2
Blue Ox
Turning Diesel Fuel Into Fun
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
Well, it looks like Stanadyne has abandoned the product, but I can give you part numbers for the O-ring and screws. Also there's a service bulletin about the screws. I'll have to do more digging on some of this, but the O-ring P/N is 22591 and the screws are P/N 22953
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
following this closely as I am replacing the entire fuel system, learning lots, thanks you guys!
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
thank you blue ox
found these
screw https://www.mycnhstore.com/us/en/caseih/category/hardware/bolts/set-screw/p/A22593
oring https://www.adiesel.com/Stanadyne/STA-22591
and some stuff I found on another site
GM parts manual
My fuel filter base started to leaking the other day, and it is making it hard to start. Have to bleed it now to start everytime. I LOVE THE INTERNET! After countless hours of searching I have found the O-rings and there GM part numbers, so here they are:
Stanadyne model 80:
Vac switch O-ring: 15593307 $4-10
Fuel heater O-ring: 15596600 $4-10
Air bleeder screw: 15535678 (includes new o-ring, its not sold seperatly) $7-8
Earlier style Vac O-ring: 15596608 $10
I can't find the one for the "water in fuel sensor" I think the whole sensor must be purchased and it includes the new (seal/o-ring). $111
Prices are different depending on where parts are bought.
I could only find the stanadyne part number for the heater O-ring: part # 15349 nsn # 5331-01-138-2106
couldn't crossreference the other numbers to the GM part numbers."
Blue Ox
LI-NY
Derek
MCMLXXXV
K20HD
6.2L
thank you blue ox
found these
GM parts manual
Stanadyne model 80:
Would be nice if they had a picture of that first one. It may or may not be correct. A "set screw" it is not.
backwoodsman
Idaho
GMC Suburban K1500
6.2L diesel
You can get O-rings at any hardware store. All you need to know is the size.
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
I imagine the material of the o-ring is important. Not sure my local ACE would have they type I need.
backwoodsman
Idaho
GMC Suburban K1500
6.2L diesel
I don't know about Ace, but most would have Viton or equivalent o-rings. If your local hardware store doesn't have them, an auto parts store certainly would.
plugugly
rocklin, ca
Damon
blazer
6.2 diesel
To close the loop on this for anyone in the future........
struggled with this for a while. Kept getting worse. Decided to swap to a duramax filter. Went with a Dorman piece from Amazon, and couldnt get it to seal. Returned that and went with one from the DMAXX store for a few dollars more. Worked like a charm and problem seems resolved. Very easy to mount to factory bracket from brick filter, just needed to drill a few holes in the bracket for the new filter housing, find some metric bolts to mount new head, and get some adapters and 1/2" fuel line to plumb it up.
sorry, my picture wont load for some reason. says security error
5280k20
