davbell22602
- Jan 16, 2011
- Bunker Hill, WV
- David
- I Dont
- Have
- One
Who sells 1/4 air die grinder bits? Lowes, sears, home depot, etc?
Just about everybody don't they??? What are you doing with them??? I bougth some cheapies at HF once just to practice taking smog NOx bumps out of heads to increase flow and they worked well for as far as I could reach with them. Then went to flex shaft on a high speed dremel motor.
Are you talking about stones or burr bits? Stones can be bought at Lowes but I've never been able to find burrs there or anywhere else locally. But I did find these carbide bits I'm wanting to get...
http://www.amazon.com/Grizzly-H6101...UTF8&coliid=IUGITS53IXHUD&colid=3ECXN8GB4WJSZ
Hope this helps!
Cutting off rivots on upper ball joints and would like brush wheel cleaning surfaces that angle grinder cant get to.
All I know is sears.com, lowes, home depot dont any bits online.
i know i am off topic but for the ball joint rivets use a air hammer and knck the heads off them and take a punch and knock the rest down thru, can have them off in minutes
Which air hammer bit do you use? We tried that at school on mine and didnt work.
perhaps the bit isn't the problem. What air hammer are you using?
I use a long barrel air hammer with a flat chisel and it cuts rite thru the rivot heads with ease.
Its kobalt one that the school has. I got a air hammer made by AmPro 2000 series.
lol told you once before if its an air tool and its not made by ingersolrand its not worth having. Tell your fly by top 10 night school to buy a GOOD long barrel air hammer and watch how fast you knock the rivots out.
