SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
Thanks for posting the additional information. To answer the question about adjusting the rear drums, no you cannot adjust them tighter, that would result in the brakes dragging to much. At the shop all we do is adjust them until the shoes just barely touch the drums, that works just fine.The trailer is a 3/4 ton truck bed, made into a trailer. frame, spring, shackles, box, topper. With a tongue and lights. Here Ill post a pic.
You must be registered for see images attachYou must be registered for see images attach
The truck i pull with is actually a 1996 F150 with 300 inline 6. It does the pull part of trailering great, but this trailer doesnt have brakes. And the rears of truck are out of adjustment(for sure) and my question is more or less, notwithstanding trailer brakes, is there an adjustment to drum brakes that would help with my purpose? I will primarily only use the truck as backup driving or when pulling something, so adjusting it for pulling weight would be best in my opinion(if there is something to adjust).
I know the proper is a certain thickness away from drum surface while rotating freely(varies, I bet, but similar on most drum brake rear) and thats with no load. If expecting to add a load, could one adjust it in a way to make it better for a trailer?
I guess I should mention there is no ABS at play in this 1996, if that was a concern. Bone stock with things bypassed or removed that dont work. That included the ABS pump in the mid 2000s.
So one of the issues with a pickup bed and frame turned into a trailer that has not been brought up yet is that the tires are not in the right place. In a trailer that was originally built to be a trailer the rear axle is quite a bit behind the center point of the trailer, this and proper loading helps to put weight on the hitch which reduces swaying, and puts some weight on to the rear of the tow vehicle. With a pickup the axle is more centered, not necessarily dead center, but most are not far enough back. My suggestion next time you use it try to load more weight in the front of the trailer, I think the trailer is pushing the truck for that reason. Also make sure the trailer tongue is level or angles slightly down towards the truck, a tongue that angles up towards the truck will exaggerate the issue.
Hopefully some of this will help.
