Adhesive Rear Cab Molding?
TruckCo
MA
Jay
Hey all,
The rear cab of my truck has no molding that wraps around the rear of the cab. I very much like the look of this however the P/O must have patched the holes because right now it is clean looking. Do they make a rear cab molding that is a "stick on" model so I do not have to drill holes in my cab again?
Thank you,
Not that I'm aware of. I've seen some people online say they just used thick 3M adhesive but don't have any direct experience. I've thought about doing it to my truck cuz it never had the trim
mxer147
Colorado
Jack
k20
I’m planning to drill the holes for the side molding and then use the 3m thick two way adhesive for the long trim piece for cab rear.
Auburn, Washington
You might be able to stick the plastic cab trim clips on with thin 3m double sided tape, but I agree, I don’t see the corner pieces holding well if at all without bolting them up like OE.
Ken B
indiana
ken
damn, i really want to add this trim but dont wanna drill the holes.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
How do those little pins even mount? Is it like a rivet? Haven't looked close at the only truck I've had, that's had the trim.
Strick
Dunn, NC
Harold
C20 Crew
I'd drill a hole and attach the clip with a screw. I've been here before & now when those brads either fall or rust out & then need replacing. I've had to improvise several for the vinyl roof on my '74 Z28 that I've been working on the last few years.
HS
Black Pearl
