Adding gauges
chappy78
Seattle Area
chappy78
That is one spendy piece of plastic there! It would be cool to do but just not gonna be in the budget. By the time I bought the bezel and all the gauges I’d be in the same price as Dakota Digital gauges which have more functionality than VDO units. I’ll keep on the hunt!
My truck is non AC but I’m looking at adding a Vintage Air unit in the future. Also I am making a block off plate to go in that area for AUX switches.
I'll also add a Vintage air unit in the future which is why I put the switches there and not any gauges. Switches will be easy to move. Those Vintage air units are $pendy!
You're probably right about the cost of the gauges. I was patient and was able to buy all the gauges on sale and I think I am ahead of the cost of the Dakota panel but it's probably close. However, I liked choosing all the components and putting it together with a little creativity so it's unique - I haven't seen any dashes like mine.
chappy78
Seattle Area
chappy78
hunters628
Ellensburg Washington
Hunter
Thanks for the compliment! There's lots of pics on my build thread. The color Hawaiian Blue, RPO code 23.
https://www.gmsquarebody.com/threads/1978-chevrolet-k20-build-and-l31r-vortec-engine-swap.27832/
Here's a couple.
Is that originally a PNW truck? Because mine is, and even though it is in good shape for a pnw truck, it has some rot. Yours looks like it has virtually none!
chappy78
Seattle Area
chappy78
Yes, as far as I know it's always been in the PNW. It was originally purchased from Brooks Biddle Chevrolet in Bothell, WA and only had three owners before me. It definitely has some rot but it's not bad. The passenger inner fender is wasted under the battery tray and both front fenders have rot in the area just aft of the front wheel wells. The doors have some cancer, too. I have all new (made in Taiwan) inner and outer fenders and doors in boxes in the garage waiting for me to prep and paint them. I am a little burned out on working on this truck after 6 months of work doing the suspension, fuel injection conversion, drivetrain overhaul, engine swap, and interior overhaul but I'll probably start on the body work in the next month or two. (It's a sickness.)
hunters628
Hunter
Mine has rot in all the same places. Nothing crazy by any means though. Only big issue is the bottom of the passenger door is completely rotted out from mice living in it. Same with the latch area of the hood. I’m just about done with my engine so I’m trying to make all my other decisions now, such as gauges, running gear, and interior.
chappy78
Seattle Area
chappy78
I hear you. Reach out if I can offer any help.
What engine are you putting in?
hunters628
Hunter
Once this social distancing bs is over I’ll have to look you up on one of my trips to Seattle. I just buttoned up a 6.2. Ive fully bare block rebuilt it and I’m cleaning all the accessories and brackets to go on now. Waiting on pay day to roll around to get a oil cooler and new oil lines. Truck was originally a 305. Please look past the nasty garage. Been a while since cleaning. I’m working lots of overtime.
82 k10 “shorty” revival
https://r.tapatalk.com/shareLink/to...”-revival.27685/&share_type=t&link_source=app
ozark plateau
dennis
k5
back in the day, used hardware cloth and bondo to make gauge pods. form a rounded hump on top of the dash so you can see em. same technique works for kick panels and speaker pods.
Kryptonitekid
Philadelphia, PA
Jeff
CK20
I put these in my non-AC K20 15 years ago. You can see them but they do take more than a glance. Only problem is reflection off the back window at night. However, my intent was to eventually make an angled mount so the would all face towards me at a slight angle. I used a hole saw. Probably would not do it so crudely now, but I do like having the gauges.
why you have two levers on transfer case? Im intrigued
5akman
CA
Lance
That’s the only thing I was really concerned about. I didn’t want them to be too distracting but I also don’t want them to be invisible. I was thinking of making a bezel to angle the gauges towards the driver but it wouldn’t work with the chassis punch and probably wouldn’t look very clean.
they make angled gauge bezels. Back in my hot boat days, you'd end up with a single row of gauges, 3' long across the boat dash. Even with the angled bezels they were tough to read on the water.
https://www.cpperformance.com/p-152-angled-billet-aluminum-gauge-bezels.aspx
BEARS208
Idaho
Creed
C10 short wide
I just bit the bullet and made my own cluster. I like the clean Factory location. Cheap No, But We're worth it. :)
clendon1
Polk City FL
Butch
c10 stepside
468 BB
You can buy the gauge adapters that allow about 30 degrees ? Angle on the gauges, I used them in my Nova with the gauges cut into the dash, worked great.
Memaloose
Dolan Springs, AZ
Tony
I too, hate to cut up a dash and all my original gauges are operational but I wanted a volt meter and an accurate oil pressure gauge that I can trust. I would have liked to add a temp gauge as well but only two fit but that's ok. I cut the back out and I can epoxy it back in later, if I want. In my '81 Custom Deluxe, I mounted 2 1/16" gauges in the dash panel where there were blanks or idiot lamps, it turned out very well.
Good luck! This '75 Scottsdale has all 4 gauges. I'm trying to keep it as original as possible. I was surprised the factory oil pressure gauge is mechanical.
496bb
AL
CL
Suburban R20
Bears208, I need more details and info on your gauge cluster mods! I have all the Phantom gauges except speedo from another project, and an extra factory bezel, just not sure about the work to make them mount in there.
GRedschoen
