AC/Heat vacuum selector valve part #
Black gold
usa
shane
What’s the part number for this? 1986
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I couldn't get one for my '85 a few years ago and had to buy the whole control. Last photo has the exploded part numbers. Look at #6.
84GMCSierra
Central Arizona
C2500
I wonder if I need one of these to get my defroster to work? It worked when I bought the truck in 2019 but it stopped but the regular heat works. I pulled all the AC components out except for the box on the firewall to clean the engine etc, so not sure if it works yet.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
I think if that valve fails it defaults to the floor or defrost. I can’t recall. I bought one of those cheap vacuum testers to make sure all the vacuum pods worked. When I determined they did, it led me to the valve being the issue.
I know the complete control assembly was under $200 when I bought it.
Black gold
usa
shane
Craig 85. Where did you buy the assembly? I bought one from LMC and it did not have the switch.
Black gold
usa
shane
Where did you purchase the assembly?
1lejohn
texas
john
k-1500, 2500 HD
Good luck finding a new unit. I got lucky and found a new in the box GM unit last year. It took many searches to find one. I got the last one from them. I had issues with the plastic, rubber, socket that the vacuum lines plugged into. The part that goes on the switch #6. I found one at the junk yard that was in better shape. It fixed most of my problems. The heat blows out of the bottom the AC out the vents , the defrost not so much.
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
Obullard74
