A Tale of Man & a Square dream
JGSR66
Mesquite Tx
Jerrie
Forgot these pretty sure this is bypassing my passenger tank
JGSR66
Mesquite Tx
Jerrie
I’m thinking since it at least runs & drives if I can get it through an inspection (hopefully just safety) and registered then I should start with suspension unless those wires on the harness block look to bad or anyone with another jump off point feel free to stick your toe in the water it needs a little everywhere just where to start?
SDJunkMan
Black Hills of South Dakota
Jeff
I would find a flexplate cover and look that oilpan over pretty good, it looks like it has taken a beating.
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Cant verify your tranny from the pic provided but use the chart below to identify yourself.
Its running and driving, but I would start before anything with a good pressure wash and engine clean. I like to get the previous owners crud off before i dig in. It also helps ID any leaks.
Full maintenance and hose inspection would be a good way to start with your kids. New plugs, wires, etc. Give em a diagram and have them check the vacuum hoses and replace as needed.
Pretty much inspect it yourself before the state does and tells you something you dont wanna hear.
x2 on what the junkman said. That pan looks BEAT.
JGSR66
Mesquite Tx
Jerrie
Thank you I’m going to get oil pan and when the rain stops a good scrubbing.
JGSR66
Mesquite Tx
Jerrie
Carburetor
JGSR66
Mesquite Tx
Jerrie
Different view
Honky Kong jr
Super Sarcastic Man
Denver,PA
J-me
Lil BB 407
Isn’t the little spring supposed to be inside the bigger one???
  • Like
Reactions: WFO
78C10BigTen
pennsylvannia
C10 BIG TEN
From what i seen id take a good look at that radiator also, looks as it may have a heafty leak. Oh and:welcome: hope to see a great family project form here
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
It looks like someone ran over the the air cleaner snorkel. I’d see about fixing that, replacing it, or at least flipping the lid in the meantime because you want your engine to breathe as much as possible.
JGSR66
Mesquite Tx
Jerrie
Those springs are from a door lol I didnt do that came ASIS. I have bought the right ones with the lil 1 in big 1.
350 w/203
Welcome to the site!
Now, GET RID OF THAT RUBBER FUEL LINE FROM THE CARB AND RUN A SOLID LINE FROM THERE TO THE FUEL PUMP!
We want you to be safe and not be a Crispy Critter...or your square body.
Once again, WELCOME! Seriously.
ben_swager
