A/C pancake compressor leaking
Gilmore
Eureka
Christopher
6.2L Diesel
As part of my Vintage air system I am using an AC Delco pancake compressor. This compressor has developed a leak at the front of the clutch right near the center bolt.
Does anyone know how to fix a leak like this maybe a new o ring or something else I can do to fix it?
I also have a small leak at the rear manifold but this is a bit more straightforward to fix by replacing the seals and orings.
350 w/203
You can get a rebuild kit but, you're going to have to find someone who can evacuate the system for you.
Gilmore
Eureka
Christopher
6.2L Diesel
I have gauges and a vacuum pump and oil for the compressor. Where can I get the kit?
350 w/203
Get the part number off of the compressor and google it with the words rebuild kit.
fast 99
Spokane, Washington
It is common for those to leak where the case seals to the steel band. Although I have replaced a lot of front seals on the older 6 piston design, never messed with one of those due to the fact they don't seem to be very durable. Always replaced the unit.
Gilmore
Eureka
Christopher
6.2L Diesel
This is the compressor not sure where the model is.
350 w/203
There should have been numbers in the silver area. I can't tell what is on the sticker under the brace to the right.
youngone
