a/c in a non a/c truck
Lostranger
Marion, NC
R30
I’m gonna try it the hard way. I no longer use the 89 GMC 3500 van that we bought new. Many of the AC parts were new shortly before I parked it. I want to use other donor parts to convert my 87 R30 to serpentine, so AC at the same time seems an almost logical choice. Wish me luck.
Lostranger
Marion, NC
R30
Is it WORTH the effort to put factory in? He told me I can have everything for free as long as I remove it, the only thing that isn’t there is the compressor. All Input is welcome.
Would be hard to stop me with that availability. Been driving my 87 R30 daily for two years without AC, and i’m Tired of the situation. I’m gonna try to adapt factory unit from an 89 van. That’s how desperate I am.
bigcountry78
Hickory, North Carolina
James
K10 Custom Deluxe
Well I went over there today, and lo and behold, there is a late 70’s short bed with the entire ac system still intact, compressor, brackets and all. Kind of got me thinking about it again. I’m not sure what all vacuum hoses I would need though.
If the system is still complete the vacuum hose harness should have everything you need. Only one hose goes through the firewall and into the engine compartment. These dwgs might be of some help:
Parts lists:
bigcountry78
James
K10 Custom Deluxe
Parts lists:
Those diagrams are a huge help, thank you for those. Unfortunately the truck that everything is on has had the engine removed, so I can’t immediately look at it and see first hand where the lines run.
lcfman
Murfreesboro, Tenn
Geary
I am in the process of installing a Vintage Air kit for my 77 C20. My problem is the v belt routing. I can not get a combination to align with the compressor/crank/power steering pump pulleys. Anybody mage this swap? If so let me know how you routed the belts. Do I need a 2 groove power steering pulley? My pump is a single groove.
jlyon1006
