A/C blower problem
77jimmy
Las vegas
Daniel
Full size jimmy
Well I only have a I-touch so I can't post pic on here. I could email you them if that's alright with you
77jimmy
Las vegas
Daniel
Full size jimmy
Well there was no junk in the blower fan. But the case that goes around the blower motor is too small the fan blades are hitting the plastic case. Any idea what I can do. I can't post pic on here but I can email them to you. Please I need help I'm stuck don't know what to do
77jimmy
Las vegas
Daniel
Full size jimmy
Well I got her all fix.
Awesome. Wish you had a cam so you could show us what you did and what type of unit you have. Important part is, you have AC now. :waytogo:
Be sure to hang out a bit, don't just come visit when you're hung up on something. :High 5:
Sljabbs
Lehi, Utah
Steve
blowing fuse
I have a 1985 Chevrolet/k10. When I turn on the A/C the heater/ac fuse blows
when I use just the vent or defrost the fuse will not blow. Any ideas?
I'd probably start checking wires at the Compressor being pinched, and/or consider the compressor or clutch drawing to much current. Unplug your AC compressor. Turn on the AC. If the fuse still blows then you know it's from the plug in back. If it doesn't blow and then it does blow the instant you hook it back up, then you know the problem is at the compressor/clutch and take it from there.
antoniomeadows777
