!987 350 tbi
Cottonman
Bryan
I bought a 1987 R10 with 350/400. Someone put non TBI heads on it when they rebuilt it. Is this a big problem?
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Shouldnt be. Performance depends on which heads were installed. TBI heads have a swirl ramp in the intake port, which promotes low end torque.
MadOgre
NA
NA
NA
NA
NA
I have never really noticed any power differences between the early TBIs and the carbureted small blocks. I did how ever notice big differences in fuel consumption between the two.
TBI heads prone to cracking, probably better off.
87ChevyR10
Kansas
NA
NA
NA
How is the intake manifold mounted? Usually non-tbi heads won't allow the tbi intake to mount without some modifications to it. Unless they used a non-tbi intake and used an adapter plate for the tbi setup.
MadOgre
NA
NA
NA
NA
NA
You can use an Edelbrock 2104 0r 3706 aluminum intake. Both are spread bore. I don't see a square bore one.
2104, 87-95 cast iron heads, non egr
3706, 87-95, cast iron heads, with egr
They look just like the performer 2101 for Quadrajets. You could use the adapter if you want to use a square bore carb.
MadOgre
NA
NA
NA
NA
NA
I don't think it would be to difficult to make your own adapter plate to mount a TBI to a square bore manifold like a 2701 for use on 86 and earlier heads. I don't know how well the system would work though ?
Otherwise there is the FAST setup.
bglendon
