95 Chevy water in passenger floor board
snappchevy
Tennessee
Clay
Hey all, my 1995 Chevy K1500 has leaking water into the passenger floorboard. Can’t find anywhere it could be leaking from. It hasn’t rained and the floorboard does not smell like antifreeze. Any info or suggestions would be greatly appreciated, thanks.
Catbox
Peter
C20 Silverado Camper Special
We have the same thing on our 1995 Sub.
My son said he found on a forum where some said it was coming from the cowl area.
I am not entirely sure where, but rain water leaks in...
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
On mine the hoses are loose in the fw
85K304SPD
Las Cruces, NM
Richard
Heater core. Mine was dripping out of the bottom of the cab. I had to loop the heater hoses... for now... Its warm enough, no heater necessary for another 6 months. The carpet is dry but kind of oily now.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
If you've used the a/c or defrost I would check the drain tube for sure. Possibly modify. I've seen some cases where just the right wind will cause the water to shoot right back up into the hose or find a way through the firewall.
If not, with no rain, its the heater core.
snappchevy
Tennessee
Clay
I should’ve mentioned the truck has the A/C option, but it is currently not working. I’ve checked the condensation drain and the liquid is not sticky.
CountKrunk
SW VA
Count
v8 350
Mine is only when it rains. Nothing obvious in the cowl area but i still need to test to make sure its draining
F1r3truck
