creich68
- Jul 2, 2023
- North Carolina
- Clay
- V1500 Burban
I've been getting some static on the right channel (front and rear) of my suburban recently. Not quite sure if it's the original radio head unit causing the issue or original speakers finally biting the dust. Pulled one of the rear speakers out to see if it listed what ohm it was rated for, but doesn't show it (picture below). I hooked up the positive/negative terminals to a meter and it leveled out at 9.7. Did GM use a 10 ohm speaker in 1991? Most of the aftermarket 4x10s I've found are 4 ohm. The LMC catalogue doesn't list what their replacement speakers are rated for either. Just seeing what options are out there that would work with the factory AC Delco head unit? I'd rather not mess with replacing the entire head unit.
