90's model heavy half bolt rear end
GMCummins
Mid-MO
Ashley
12 Valve Cummins
Is the 90's model heavy half rear end 14 bolt wider than the 80's model 10 bolt rear end?
Yes, if it's from a 4x4 truck. It's similar in width to a 6-lug front axle.
GMCummins
Mid-MO
Ashley
12 Valve Cummins
I'm trying to get my front and rear end to line up without having to use wheel spacers.
MadOgre
NA
NA
NA
NA
NA
The added benefit is that I believe the years to be 95-99ish that the 14 SF has factory disc brakes with a drum parking brake built into it.
GMCummins
Mid-MO
Ashley
12 Valve Cummins
Has anyone changed their rear end and got them to line up? If so what did you use? I was going to just use wheel spacers but I read that you have to be careful with which ones you get.
MadOgre
NA
NA
NA
NA
NA
Ive heard that the wheel spacers that use this style are stronger.
However I would think that this style would be stronger. But what do I know. Not enough apparently!
350runner
tx
Ceasar
IIRC getting the front and rear lining up was a bonus of doing this swap.
GMCummins
Mid-MO
Ashley
12 Valve Cummins
Ilrc?
350runner
tx
Ceasar
If I Remember Correctly
Don5
West Virginia
Don
k15
IIRC-If I recall Correctly.:)
GMCummins
Mid-MO
Ashley
12 Valve Cummins
OK gotcha thanks! I found a heavy half rear end for pretty cheap but I didn't know for sure if it would help me with my dilemma. After I put those new wheels and tires on there this weekend you can really notice the width difference.
MadOgre
NA
NA
NA
NA
NA
Im lost. Please explain what helped what ???
GMCummins
Mid-MO
Ashley
12 Valve Cummins
I was saying I didn't know for sure if that rear end would fix my width issues. Help my dilemma of finding a wider rear end.
BowTieJockey
Tallahassee fl.
Trey
On the other plus side you can find a 6 lug 14 bolt from the 88-98 trucks and be 3/4 ton with the 6 lug pattern too. That's of course if your 4 wheel drive of course.
BowTieJockey
Tallahassee fl.
Trey
Forgot to mention that the 6 lug 14 bolt is a semi float but still stronger than the 10 bolt.
Carbajal73
