89S 350 TBI Head Gasket Replacement Project
Swims350
Logan WV
none
that's what I said a bad lifter or wiped lobe. next up.....
89suburban's cam swap project 5.7 tbi...... stay tuned.
davbell22602
Bunker Hill, WV
I Dont
Have
One
I still think those new heads caused rod bearing to spin/spun.
Swims350
Logan WV
none
eh maybe but a top end knock or tap and a bottom end are easy to tell apart most of the time just by the sound and where it's coming from.
jake wells
Can i be me?
Brownsville Kentucky
jake
custom deluxe 10
you might possibly have a wiped cam or collapsed lifter. and if you crossed a wire on the truck you would know it by the back firing through the TBI when you press on the throttle and rough idle.
Maybe it's your flux capacitor going out......
I got a small backfire through the intake under fast, hard accel. That's what made my mechanic think it's a lobe/lifeter. I can;t even bear the thought of tearing this thing apart again. :suicide:
I tried to pull plug wires one by one to try and narrow down to wichh cylinder it is but I get shocked to ****, and that's wearing leather gloves and rubber handled pliers. F that. :sad72:
Really??? That shouldn't happen!! Do you have an arc some where?
jake wells
Can i be me?
jake
custom deluxe 10
sounds like a burnt valve to but it has a new head
It did the smae thing when I tried to adjust the timing, shocked the **** out of me with leather gloves on.
:think: That just should not happen but I'm not electrical enough to tell you how to fix that :sad72: Maybe Retro might have an idea....
If I got shocked like that I'd probably start taking a baseball bat to it but that's how I deal with pain. For some reason pain instantly sets of my anger button. Not sure why :shrug:
davbell22602
Bunker Hill, WV
I Dont
Have
One
89S,
I still got 350TBI engine and its still hooked up to the hoist. All I have to unbolt the trany and unhook the wiring harness from the trany.
I defiantely got pissed off and had to walk it off, f'n this and f'n that while I did so, lol. That **** scares me.
jjrussell88
