89 Trans Am
yevgenievich
Place
Name
Year
Model
Size
Moving along. A arms are done and set aside. They were a pain to deal with. Notched the k member for ls1 ac compressor and also added a notch for running a brake line. Waiting on oil pan gasket to put everything back together.
74 Shortbed
Coming along nicely.:waytogo:
Too bad you didn't know to wait till now to cut out the spring pockets.
yevgenievich
Place
Name
Year
Model
Size
Should have just went in to do everything at once. I actually had a discussion about taking the k member out to begin with but scrapped the idea originally.
yevgenievich
Place
Name
Year
Model
Size
Not much done today. Dropped the oil pan, cleaned and installed with a new gasket. Washed the used ac compressor, but not mounted yet.
Also bolted the mounts back to the block.
It's kinda surprising to see a pan gasket leaking on an LS. I had a rear main leaking pretty good on my old 4.8, but that seal likely failed because the camshaft that had lobes wearing off. The oil was glittery everytime I changed it, lol.
I've had the pan gasket and rear main seal replaced on my burb with the 5.3 and my truck with the 4.8 needs the same treatment. It happens with age.
Interesting. I guess I got out of the biz before it started becoming common.
Maybe. the rear main and oil pan on my burb needed done around the 180k mark. my truck has 215k on it now and has needed done since I bought it. I have the stuff to do it now but just not the time just yet.
yevgenievich
Place
Name
Year
Model
Size
for almost a 20 year old motor, it is doing decent. The front seal is also leaking, but I am not touching it at this time. Hoping to get it back together today for alignment tomorrow
yevgenievich
Place
Name
Year
Model
Size
Almost, but not done yet. Left to finish the oil change, drill couple of holes for mounting the brake line in a new location and install wheels.
yevgenievich
Place
Name
Year
Model
Size
Going for alignment tomorrow morning. Fresh oil, oil filter, secured the brake line, mounted wheels and readjusted height. Hood hits the strut brace, so that would need to be modified before installing.
yevgenievich
Place
Name
Year
Model
Size
And aligned. Now at some point need to install new door hinge pins and a lot of other items to take care of.
GorillaHumper
