89v1500
- Dec 5, 2024
- Texas
- Isaac
- Suburban V1500
- 350 TBI
Howdy!
I recently purchased a 1989 GMC Suburban V1500. It has been off the road since sometime around 2006. Just got it back up and running with a new fuel tank, pump, and injectors. Quickly noticed that the gauges didn't work! Checked the fuse and it was blown. Tried putting another one in and the gauge lights came on, but as soon as I cranked up the truck I heard a "POP" and gauges were dead again. I've tried unplugging a couple components to see if the fuse would stop blowing, including the gauge cluster, warning buzzer, brake switch (torque converter clutch solenoid?), and one module thing that connected to a screwed-down plug butted up against the speedometer cable on the gauge cluster. None fixed the issue. I found a wiring diagram but I'm having a hard time following it. The gage/idle fuse feeds a pink/black wire, circuit 39, but so does fuse 4 right above it, labeled ignition! Could there be an issue with the ignition circuit that is causing a different fuse to blow? I know there is a short to ground somewhere just having a hard time finding it. Would feel much more comfortable to run the truck if I knew what the oil pressure was and the engine temp (although I'm sure these gauges are not very accurate).
Does anyone have an idea on things to check for? Or has anyone experienced the same issue and found a solution? Any ideas would be a huge help. Thanks!
