88 c30 cranks long time before starting.
Donnie Kingrey
NWI Indiana
Donnie
c30
I recently bought a 88 c30. 454. The guy I bought it from put new cap, rotor, plugs and wires in it. When starting it seems to take a long time to fire up. It cranks for several seconds before it starts. One time it would not start. Let it set overnight and it started. Looking for some direction. It has two new tanks with sending units also.
Thanks
Crispy
Carbon County, Pennsyltucky
Suburban V1500
Have the battery load tested for starters. I chased a problem like this down for a while and found it was my battery. It would long crank when the vehicle was cold (and when the ambient temps were cold) In warmer weather it would crank right up. Other places to test are the fuel pump relay and oil pressure sender. Those systems are tied in together and can cause a hard starting problem.
Get in the truck and turn the key on but dont start, make sure to listen for the fuel pump priming. It primes for a couple of seconds then shuts off. If its not doing this then check the fuel pump relay. Its bolted to firewall to the right of the underhood light.
Also, when you do finally crank the motor over, look at your oil pressure gauge and take note if it builds pressure before finally lighting off.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Donnie Kingrey
NWI Indiana
Donnie
c30
They guy I bought it from done about everything except a TBI rebuild. The back story of the truck is it spent it’s life in Tucson. When he got it it was non running. He put new tanks,sending units and pumps in it. New cap, wires and rotor.
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
Subscribing
I have an '88 burb that does the same thing. Once it cranks for the first time, it cranks normally afterwards.
Outside temp doesn't seem to make a difference.
Fuel pump primes
Oil pressure only increases once cranked.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
If you have a matching, consistent injector spray while cranking, it might be spark related. I’d check for distributor cap corrosion, distributor rust, a shift in initial timing, or other failing high energy components, particularly the pickup coil and the HEI coil.
Tanked
WPB FLA
denis
R20
Mine does the same thing but watching the oil pressure gauge is very good advice that's as far as I got it I tried grounding the oil sending unit and seeing if that works that did not work turns out that's not the computer oil sending unit the oil sending unit for the computer is behind the distributor with two pins. I'm still looking I'm thinking of jumping those out
RanchWelder
Earth
Blazer
350ci
Have fun!
ben_swager
