88-91 antenna base
Slooptin
Denver
Vance
k30
Anyone know if anyone still makes the non-labeled part below? my antenna recently snapped off in the base and I havent had luck backing the broken stud out.
gmbellew
Kansas city
glen
suburban 1500
I'd be interested to hear back how any of those fit. They don't look quite right to me.
The AC Delco one looks correct from the grainy pictures, with the exception of one deleted screw hole. The cable length may differ (perhaps longer) because that antenna base was used on a few GM models.
gmbellew
Kansas city
glen
suburban 1500
the deleted screw hole was what was throwing me off. hopefully someone will be the guinea pig and let us know it fits!
Slooptin
Denver
Vance
k30
I guess I'll try it out. Thanks
Urbanburban22
Colorado
Suburban SLE V1500
5.7 TBI
I bought,
GM Genuine Parts 15829166​
off the Ole Scamazon and I Don't recommend it unless you are willing to "Make" it work, it dose not fit the square burbans.
Raider L
Shreveport, LA
William
Okay, Summit Racing has several fender antenna's, other's are Crutchfield, and gmpartsonline.net, and if you type in "'90 Suburban fender antenna", it will pull up a box with a bunch of example's of fender antenna's for these type vehicle. Also, if you go to Ebay under, 31" Black Antenna Mast Power Radio AM/FM for Chevy Suburban 1988-2006 Brand New, the guy is showing a antenna fitted into the trim at the base of the windshield, but in his photo's he's got an older 'burb with the rectangular base on it sitting on top of the back corner of the fender. So there you go. All kinds of things.
ESONE
