Thsalespts
- Aug 11, 2019
- Daytona
- Michael
- P30
I have a truck stranded that I need help to get running.
Injector on driver side works perfect.
The injector on passenger side just stay wide open and never stops spraying fuel. I unplugged it and truck will run rough off just the working injector.
What can cause 1 injector to stay wide open and 1 to work perfectly fine?
I believe they are individually controlled in ecu so I can only assume one of the drivers is bad?
Each one has an A side and B side is there a way to temporarily wire it run correctly.
