gmbellew
- May 27, 2018
- Kansas city
- glen
- suburban 1500
if you dont turn it off, and take off does it run fine after it starts stumbling? is it only when stopped in drive? what about putting it in park and reving it after you stop and it stumbles? if you just let it warm up at idle, will it stumble when it is fully warmed up?
if it isn't related to closed loop, you may need to try a new distributor. if thats not it, it could be a mechanical issue like low compression?
if it is only in drive, it could be transmission related.
