86 1/2 Ton Suburban lift help!!!!!
Chaz
USA
Chaz
V1500 Suburban
350 tbi/th400/np241c
Now that you said that I recall my truck does have the spacers on the crossmember,,,,bout an inch,,,,I guess that is the t case drop down,,,,
The ord sway bar disconnect works easy enough but I cant disconnect mine and lock the bar up yet because my brake line is in the way,,,
86-K10-Burban
Windsor, On
Zachary
Will the brake line relocation be much of a problem to get the sway bar disconnect to work properly?
Also did you have to modify the hole where the transfer case shifter sticks through, or was there enough room to still put the truck into 4-low.
Oh okay thanks, I have to think about it then. Was the truck sagging in the rear of the photo, or was it just the way the photo was taken?
The rear had lift blocks on tired factory springs so it had that Calii lean. Plus the rear tire was flat in that pic.
86-K10-Burban
Windsor, On
Zachary
thats not too bad then. When I lift mine i will be getting a full spring lift. My leafs arent in the best shape. Plus not a fan of blocks but they work and there cheap.
thom9719
