Westislander
- Nov 3, 2018
- Massachusetts
- Gregg
- K10
How do you remove the aluminum Silverado trim that is below the tailgate insert. I know the one on the back of the cab will slide off when you remove the corner trim pieces. Although the piece is similar it does not look like it slides off the end. Possibly press down and roll off? I was hoping for some guidance before I torn it into a pretzel.....TIA for your help
